Old 07-01-2006, 06:35 PM
Back in Black's Avatar
Back in Black Back in Black is offline
Cobra Make, Engine: West Coast. 514 / 6 speed Richmond overdrive
Tom, good to see you here.. and once again many thinks for EFI conversion info you're offered me.
#2 possibility is I think out of the picture as the oil drains nicely from the heads
#1 is a possibility that I think our bleed down test will catch?
#3 possibility.. yes, here is something to look at if we eliminate other possibilities and actually fire it up again
Thing that's bothering me is everything was good (no real oil leakage) with the PCV breather installed as before. Yes a bit of blue smoke was issuing from the sidepipes, but not too bad (I thought) My dilemma is this tech guy who is doing it is very highly recommended and seems very talented but I'm wondering that if he tuned it with the PCV disconnected then how's it going to run properly when it has to be reconnected? Won't it run leaner? He said it was running somewhat rich with the PCV removed..
PS: Great to hear you and your cobra are both well and back on the street again!
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
