Old 07-03-2006, 04:00 AM
venom0427's Avatar
venom0427 venom0427 is offline
also try to cut the exccsess of the belt as it will be to long, pull the belt right out of the holding unit, have a small ruler in hand and pull the belt out of the reel from the back, once you have the belt out cut off about 250mm (aprox) this will take up the extra slack from the belt, now you burn the end of the belt and replace it as the same way you removed it from the reel. walla ( i think thats how you speel it) you have a shorter belt and also feels a lot better when your in the car. hope this hepls. david
