Old 07-04-2006, 07:52 AM
SuperHart's Avatar
SuperHart SuperHart is offline
Cobra Make, Engine: Cobra Fibercraft Bodies 427 S/C, 351W disguised as a 427.
Send a message via AIM to SuperHart
I run a Canton Road Race oil pan and a Mocal sandwich type thermostat with -10 oil lines on my 351W. Fortunately, I have enough room to also use the standard oil filter rather than the FL-300 shorty. When the oil temp is below that required to open the thermostat I get 65 lbs. at idle using 10-40. I can tell when the thermostat opens because the pressure then drops to 58 lbs. at idle. I have run this setup for four years now with no concerns. The setup is simple and effective.
Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
