Old 07-05-2006, 04:23 PM
Back in Black's Avatar
Back in Black Back in Black is offline
Cobra Make, Engine: West Coast. 514 / 6 speed Richmond overdrive
Great news, we did a complete compression test and all cylinders are virtually identical, two pumps per cylinder made 150 PSI, more pumps much higher and still identical across the board, less than 2 PSI difference!
Plugs look a bit rich but not wet at all, no oil usage.. what I thought was slight oil smoke out the sidepipes was likely mostly slightly rich running, possibly due to the PCV valve being disconnected
Shop that was doing the work seems to be the problem.. no understanding of these large bore super stroker engines. Many people have told me these engines must have a PCV valve or they will have problems (which is why I installed it in the first place)
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
