Old 07-05-2006, 09:34 PM
Back in Black's Avatar
Back in Black Back in Black is offline
Cobra Make, Engine: West Coast. 514 / 6 speed Richmond overdrive
To clarify the PCV is run into the intake and has a high quality billet aluminum breather on the opposite valve cover to pull fresh air from
What I thought was oil smoke must have mostly been simply rich running. There's no sign of oil burning in that engine and it looks to be fine. Plugs look nice and dry
The person dynoing and programming my car was the problem.. although highly recommended by several people and seemingly a well set up shop he (The owner) apparently knew less about this specific issue than I do, which is to say not much. That's the optomistic view of his intents. I'm just going to move on and get someone to properly program my ECU so I can finally drive my machine
The shop also knocked my front bumper out of true (shoved in on one side) but that's another issue and no doubt easy to fix. I only noticed it after I got home tonight
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
