Old 07-07-2006, 05:58 PM
edwhite7 edwhite7 is offline
Cobra Make, Engine: Contemporary, Shelby Alum 427, Dove heads
If I understand it correctly the residual pressure valve is designed to hold about 2 bs in the line on cars that have the master cylinder below the wheel cylinders. If this is not the case then they can be removed but even so they should not be a problem unless thery have failed. I had residual pressure valves in my car and I removed them. I did not notice any change but my master cylinder is above the wheel cylinders. It sounds like the pedal free play is not the issue, I suspect the master cylinder but only cause it can't be much else.
In school 90% is exceptional, in life 10% wrong is failure.
