Old 07-11-2006, 03:09 PM
JCoop's Avatar
JCoop JCoop is offline
Cobra Make, Engine: Superformance, FRP460 Big Block
Default Decceleration backfire but only RH side
Hi all,
This just started happening on my SPF/460, and not all the time. It all started when my RH sidepipe support bracket broke (common, I'm told) welded it, broke again, finally welded a bent rod "spine" under it. My collector bolts were lose so I attempted to tighten as best I could. It's really tight in there. No breaks so far, but the backfiring has started. Only as I lift off on the throttle as I shift to the next higher gear.
Is this air getting into the exhaust? Do I have to redo the manifold gasket and collector gasket? Is there a quick fix?
Thanks
Ray
New York
SPF#1052 11mpg
CAV GT40 MONO29 9mpg
'01 MB CL600 V12 18mpg
'08 Volvo S80 18mpg
