Old 07-11-2006, 06:18 PM
PCC's Avatar
PCC PCC is offline
Ray,
Just gone through the same problem with my EFI 302 motor.
Slight loss of power associated with a misfire when changing gear (heard through one exhaust only).
Replaced exhaust intake gaskets and plenum gasket and cleaned injectors - now running as it should.
Problem with mine was that I don't have a diagnostics plug on the engine resulting in a fair bit of searching to find the cause.
Air getting into the exhaust results in a lean engine which is over compensated by the fuel mixture thereby producing the misfire and excessive fuel usage (no longer cheap in Ozzie land)
Good luck mate
PCC (Peter Craig)
Keep the sun shining
