Old 07-13-2006, 08:13 AM
HSSS427's Avatar
HSSS427 HSSS427 is offline
Cobra Make, Engine: ERA #414 427 s/o w. Shelby Aluminum heads, Edelbrock Performer RPM Intake, Mighty Demon 750, Tremec TKO 600
Tony - yeah I did that to try a compression test and did it for leak down. Since the valve was sticking I didn't get much of a reading. However, after tapping the valve I got an appropriate leak down test reading.
Couple of thoughts - the engine has been sitting, and there's little or no oil that's been pumped back up to the heads so maybe that caused the sticking since I've just been turning it over by hand. Will also check the clearance on the push rods.
WhatsaCobra - thanks for the detailed explanation - it helps to better understand what is going on. To my point above, do you think it could just be lack of oil on the valve at this point? Maybe I need to prime the oil system first via the distributor hole and a drill.
