Old 07-13-2006, 12:52 PM
PJS50's Avatar
PJS50 PJS50 is offline
Cobra Make, Engine: SPF#131 520 cubes; 650 HP
A new header to sidepipe gasket/collector gasket and ALL NEW Grade 8 STEEL nuts/bolt should fix you right up...
When your hanger broke, the pipe weight, along with the loose bolts to the headers/collector probably tweeked your gasket and retightening would no longer be a good "fix"....
Shooter...Looter...Not Neutered.
