Old 07-18-2006, 09:23 AM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
I have taken two long 5/16" bolts and screwed them in about 1/2" and then I took a breakover and put it between the two bolts and then turned the flywheel until the breakover would wedge against the frame. Then loosen each bolt on the flywheel and remove the breakover. Probably not the best way to do things but it worked several times with no damage to anything.
Clois
"Let's roll"
"Be part of Something Good
