Old 07-19-2006, 12:27 PM
xlr8or's Avatar
xlr8or xlr8or is offline
That's the idea but it sounds like the relay is stuck in the wrong position giving constant power to the light.
I believe in most setups the blinker switch controls which output on the relay is powered and the flasher just makes it pulse. Since the right side works normally you can assume the flasher is working correctly.
