Well, yes... some core shift is ok, some cracks are ok if properly repaired. Most of the marine and industial service blocks were this way and operated fine up to 3,000 rpm. The issue is longevity and the balance / clearance / harmonic issues that occur over 6,000 rpm. You know 427 blocks were color coded from ford for quality right. The best highest quality blocks were pulled off the line and sent to HM & Shelby for racing use. I guess it depends on how fast you want to go and how long you want to go that fast.
You say "new" block. Are you looking for a NOS block or do you man new to you. Perfect NOS blocks are out there but they command a permium. $4,000-5000 for NOS block is not uncommon. I opted for a .015" over fully machined rebuilt unit with MR heads, 2.25" valves ready to assemble that had lived one incarnation as a 1960's-1970's race engine. I essentially traded .015" of overbore for a fully machined (NOS blocks need a couple dozen hours of perp / machine work to be race ready) engine. The heads were similarly worked over. and would have cost $3,000. to duplicate.
Have you ruled out a Genesis block or a Pond block?
michael
A man that is young in years, may be old in hours, if he have lost no time. But that happeneth rarely. Generally, youth is like the first cogitations, not so wise as the second. For there is a youth in thoughts, as well as in ages... Sir Francis Bacon (1561-1626)
