Old 07-20-2006, 11:17 PM
Carnut427 Carnut427 is offline
Cobra Make, Engine: ERA 427 w/496 Side Oiler, roller, dual quads
What is the motor going to be used for? You should know if anything has ever been machined, such as the engine deck or heads, which would require a shorter pushrod. Only if the engine has never been machined (well, a .010 cut would be OK) should you use stock length pushrods. Do a search here on checking pushrod length or something similar to find the pushrod length you need. You can make an adjustable pushrod by cutting 3/4" out of a pushrod, tapping the cut ends to 5/16", cut a bolt off or use "allthread" and a couple nuts to lock the pushrod to different lengths as you check the pattern on the top of the valve stem, which should be centered and as small (short travel across valve stem) as possible. You can use carbon paper, magic marker or whatever to mark the valve stem. You can then order pushrods to the length you need, they come in .050 length increments, from most pushrod makers. Smith Brothers do this as a specialty and have fast service, but you pay for it.
Good Luck,
Dan
Do you know why they call it "PMS"? Because "Mad Cow Disease" was taken. --Unknown, presumed deceased
