Old 07-20-2006, 11:32 PM
Carnut427 Carnut427 is offline
Cobra Make, Engine: ERA 427 w/496 Side Oiler, roller, dual quads
I got the info I posted from Edelbrock's site. FE heads came with 2 different port sizes in their low risers; don't confuse the short low riser port with medium riser ports, although both will, as you say, cause a mismatch, but will work. Cobra Jets and 427 low riser heads both used the tall low riser ports; 390s came with both tall and short ports. The Edelbrock 427 heads aren't actually medium risers, as the combustion chambers are smaller, which is a good thing. More info, if interested, can obviously be acquired from Edelbrock.
Good Luck,
Dan
Do you know why they call it "PMS"? Because "Mad Cow Disease" was taken. --Unknown, presumed deceased
