Old 07-21-2006, 03:38 AM
Ant Ant is offline
Default Holley carb to air filter top clearance?
With running a Nascar style manifold and Pro-systems Holley on my 9.2" deck height, Yates 373 engine, I am having to fit a larger hood scoop and fabricate a dropped air filter base. I have worked out minimum air filter required for me to run 7500rpms is a 16" x 3" K&N or suchlike, but I am going to have to go to about 2 - 3" on the dropped base, so I am unsure of how the air flow likes going over the carb from underneath instead of in the side and just doing a 90 degree turn, underneath probably is 120 degree suchlike turn!
Further to this problem, due to this high manifold I can only really utilise a 1/2" heat spacer under the carb, room for an air filter is 2" above the air filter flange, and that will necessitate me to shorten and angle the two bowl air pipes that sit up about 1" on top, or plumb tubes from them.
Then the post question, a carb that flows up to 950cfm (actual 750cfm) must need a minumum clearance above the filter flange/venturi's to top of filter?
A J. Newton
The 1960's rocked!
