Old 07-25-2006, 08:26 AM
Zoom This's Avatar
Zoom This Zoom This is offline
The Barry Grant carb line does have carbs - Mighty Demon - that use the Idle Eze to add additional air to the idle circuit without having to drill holes in the throttle blades. I had an 850 Holley with drilled throttle blades and a major massage from Jet Performance on my 418W, and after 2 years of fussing I gave up on trying to get it to work correctly for idle and off idle throttle response. The carb was just too big for 418 c.i. at 6000 rpm with 93% VE. I went to a smaller BG Mighty Demon carb, and what a difference in throttle response, torque, idle cleaned up, and gas economy even got better.
If you decide to drill the butterflies, start at 1/16 inch drill bit and work up from there. Go no bigger than 1/8 inch in diameter. Remember, you can't make the holes smaller once they're drilled. Drill the holes in the throttle blade on the opposite side away from the idle port. Jet Perf did drill mine on the idle port side however. All 4 throttle blades should be drilled if you have 4 corner idle mix screws. This allows more air into the motor at idle without having to turn the idle speed screw any farther past the transfer slot. Once you're too far past the transfer slot your motor becomes pig rich at idle. When you have the carb off the motor, look at the tranfer slot and throttle blade(s) relationship and make sure your idle speed screw has the throttle blade no more than .010 - .020 open into the transfer slot. Once you have succeeded in settling on the hole sizes, you need to reset your timing, idle speed and idle mix screws. After the holes are drilled to your satisfaction the idle speed should increase, thus allowing you to turn down the idle speed screw - this is good. Initial timing should be as much as the starter can handle, or about 18-20 degrees initial and then whatever total timing is best for your motor. My 418W has a MSD Pro Billet distributor with a 14 degree bushing from 4secondsflat.com and a total timing of 34 degrees. You really have to get the timing down pat before you can expect to get max off idle and throttle response. Good luck.
