Old 07-25-2006, 10:45 AM
trularin's Avatar
trularin trularin is offline
Member of the north
Cobra Make, Engine: A Cobra
Make a fresh circuit as the increase in current draw will cause the wiring to get down right hot if not rated for the Amperage being drawn.
you can connect a line from the battery to a relay rated at 30 Amps and then pass the switched line to the dual fans. Use a switch or thermal switch to turn on the relay.
Hope this helps.
