Old 07-27-2006, 08:53 AM
SCOBRAC's Avatar
SCOBRAC SCOBRAC is offline
Cobra Make, Engine: -Sold- Contemporary 427S/C # CCX-3152 1966 427 Med Rise Side Oiler, 8v 3.54:1 Salisbury IRS, Koni's.. (Now I'm riding Harleys)
Thanks Rick,
I thought my snap ring drama was long forgotten. Indeed I had one of the access plugs pop out of my crank. My plug was in my pan or it would have been a very curious leak. It's possible yours is simply partially unseated. I am looking for the thread on the problem but it seems to be missing.
I didn't have any particular symptoms prior and I "got on it" one day, not near 7,000 but my oil pressure dropped from 75-85 to about 35 at speed. I drove it home (probably a bad idea) I kept the pressure up by keeping the rpm's up over 1500. The pressure looked like it would have crashed under 1500.
Long story short I found a .875" freeze plug in my pan. It looked like the guy prepping the crank used .750" internal snap rings instread of the .875" units. I ended up replacing several plugs which looked like they had moved slightly and all the internal snap rings. All of this was done with simple hand tools and a brass mallet, snap ring pliers. The plugs are just 7/8" freeze plugs and the clips I wound up getting at Home Depot. There are better spiral lock type clips out there but of all the OEM style clips I looked at Home Depot had the strongest. Total cost for parts was like $7. and a couple of oil pan gaskets.
Good Luck!
michael
A man that is young in years, may be old in hours, if he have lost no time. But that happeneth rarely. Generally, youth is like the first cogitations, not so wise as the second. For there is a youth in thoughts, as well as in ages... Sir Francis Bacon (1561-1626)
