Old 07-27-2006, 09:11 PM
doublepumper doublepumper is offline
Default Loaded Cobra for Sale (pics in my gallery)
FOR SALE
1965 427 Shelby Cobra Replica
MANUFACTURER – Factory Five Racing (FFR)
PAINT
· Dark blue (Dodge Patriot Blue) w/ white racing stripes correctly tapered
ENGINE – Ford Racing 392 cu.in. (530 hp)
· New AFR 185 aluminum heads
· Ford Racing 1.65 aluminum needle bearing roller rocker arms
· Custom CNC Diamond Pistons
· Demon 750 carb. w/ mechanical secondaries
· Ford Racing aluminum radiator and aftermarket aluminum expansion tank and overflow tank
· March aluminum underdrive pullies
· Fully baffled road race (Aviad replica) oil pan with windage tray
· Period correct oil cooler with billet oil thermostat and oil accumulator
· Lokar braided stainless steel throttle cable and oil dipstick
· Aluminum oil breather tank
TRANSMISSION & CLUTCH
· Tremec 3550 5spd transmission
· Spec Stage 2 Kevlar clutch
IGNITION
· MSD Billet Distributor
· MSD 6AL Ignition Box
· MSD Ford TFI Coil
· MSD 8.5mm Superconductor spark plug wires
SUSPENSION
· Fully Independent Rear Suspension (IRS) w/ aluminum 8.8 center section and heim-jointed tubular control arms
· Vintage Motorsports solid aluminum mounts for center section
· Vintage Motorsports urethane bushings for IRS knuckles
· Torsen differential
· 3.27 gears
· Pro-Shocks coil-overs on all four corners
· FFR tubular lower front control arms
· Adjustable front upper control arms
STEERING
· Flaming River 15:1 manual steering rack w/ needle bearing universal joints and solid aluminum mounts
· FFR bumpsteer kit
· One piece steering shaft
WHEELS & TIRES
· Trigo 15” pin drive aluminum wheels w/ forged aluminum spinners and steel adapters
· Goodyear Eagle GTII 235-60-15’s front and 295-60-15’s rear
INTERIOR
· Breeze Automotive aftermarket plush carpet for cockpit and trunk
· Black leather FFR seats
· Simpson 5-point harnesses
· Leather dash, parking brake boot, and door pockets
· Custom polished aluminum parking brake handle (Mike’s Custom Cobra Parts)
· Polished aluminum seat harness trim bezels (Finishline)
· Custom polished aluminum parking brake bezel (Mike’s Custom Cobra Parts)
· Hella battery cut-off switch
· Custom aluminum dead pedal
· Reproduction AC clutch and brake pedals (Finishline)
· Custom aluminum throttle pedal (Finishline)
· Original Smiths gauges w/ reverse 180 mph speedometer (gas, oil pressure, oil temp., water temp., Tachometer, ampmeter) in original competition layout
· Original Lucas toggle switches
· Drive and passenger footbox cooling sytem with integrated blower fans, vents, and ducting
· Chrome reverse lock-out shifter
EXTERIOR
· Chrome Rollbar
· Internal trunk hinges
· Hood hinge
· Riveted reproduction aluminum hoodscoop
· Chrome quickjacks
· Polished aluminum rollbar bezels (Finishline)
· Reproduction aluminum side louvers
· Tonneau cover w/ stainless steel lift-a-dot fasteners
· Authentic Shelby Cobra hood and deck badges and Ford 427 side emblems
· Windwings and Sunvisors w/ stainless steel hardware
MISC.
· Black powder coated frame
· Black powder coated front spindles
· Black powder coated control arms (front and rear)
· Energy Suspension Urethane motor and transmission mounts
· 4 wheel disc brakes
· Custom 33 gallon aluminum fuel tank with internal sending unit
· Period correct self canceling turn signal with integral high/low beam toggle
· “Cermachrome” ceramic coated period correct 4 into 4 sidepipes and headers (Tristate Motorsports)
· Optima Red Top battery mounted in a custom aluminum box accessed through the trunk floor
· Suspension grade stainless bolts, washers and nuts used throughout car
· Custom stainless steel hood prop rod
· Braided stainless steel flexible brake lines
· Titled as a 1965 Ford Cobra
I'm selling to help finance my first house purchase. This is an extremely nice and well built FFR roadster
A must see to appreciate. Much invested. Asking $45,000
Pictures can be seen at http://www.clubcobra.com/photopost/s...0&ppuser=14305
