Old 07-28-2006, 06:46 PM
Alex Evonosky Alex Evonosky is offline
Cobra Make, Engine: Building from scratch
Default 5 Years!!
Find you a good engine hoist,
Pull the engine
Take it apart, clean it up
Check tolerances, and re assemble it with fresh gaskets
Buy a new carb. Flush lines before you install the new fuel pump you will need.
And that is just the engine.
Do the same with brakes. Be sure to flush lines while you are rebuilding the calipers and replacing the master cyl..
This is a start but for the cost you stated why not do ir right.....
Good Luck
Cobracer#15
