Old 07-29-2006, 06:21 AM
Rebel1 Rebel1 is offline
Originally Posted by LoBelly
Thanks Mike
Yes - that's the final position. The build manual says it should go behind the LHS rear wheel but it would have to be a smaller battery.
With the battery box that is the only place it will all fit. Still leaves room for a couple of bottles
LoBelly
Oi LB, actually a better place for the battery it in the shelf over the rear suspension on the very left. All you need is a some form of shallow box to insert into the shelf and sit on the frame underneath. My box is glass but many are alloy. It's about 3" deep and gives the height to install the battery. Gets it right out of the way and gives you more room in the boot (trunk).
I just made a simple box mould out of MDF and glassed up a shallow tray.
