Old 08-01-2006, 05:45 PM
Jamo's Avatar
Jamo Jamo is offline
Super Moderator
Run a new power line to the two pushers, although they can share off the new line. That new line should have it's own relay, with it's own separate power from the fuse box. The puller should already be set up this way. You can then share the switch for both the pushers and the puller with lines running to the two relays.
Jamo
