Thread: Bore & Stroke?
  #25 (permalink)
Old 08-02-2006, 07:47 PM
cleandan cleandan is offline
Originally Posted by 427SnakeSC
It will soon be getting down to the wire on the Keith Craft build of my 427 SO. I would like to know which bore & stroke is the best to get and why. At his point I have talked with Keith and some of the specs on the motor are as follows. Stage 1 Edelbrock Heads, Blue Thunder Med Rise Intake, 750 Holley, fairly mild hydralic roller cam and 10 - 1 pistons. Cast Pond block. He has suggested the 482 bore. Thanks.
Unless the displacement is limited by some sanctioned race body you intend to compete in, I say do what you want. My suggestion would be to examine all available bore/stroke/rod/crank options and pick one that has a good rod ratio, a bore that is not to the max of the blocks ability for future boring needs, and that uses the most common parts. Good luck.
You can't make anything everything proof, so have fun and be careful.
