Old 08-06-2006, 04:00 PM
Nor Cal Al Nor Cal Al is offline
Cobra Make, Engine: Cobra-less
I was under the impression that Dot 3 and Dot 5 were not compatable and that you had to a teardown and flush if you wanted to switch? I am running Castrol in the clutch and I put a heat wrap around the clutch cylinder. Prior to that, I did cook the fluid once and have a replacement clutch cylinder and rebuild kit for the throwout piston to put in. The fluid was black like it had piston material in it.
Cobras Gone But Not Forgotten
