Thread: Oil pressure 0
Old 08-06-2006, 11:50 PM
mobilenuke mobilenuke is offline
Cobra Make, Engine: SPF136 427FE
Default Oil pressure 0
Fired up the 63 427so and noticed the oil pressure was O , shut her down immediately. Pulled the driver side valve cover to look around.I reviewed and searched this site but couldn't find any info as to how much oil should be visable and if oil pump spun by drill how fast should the flow be. I'm trying to see if I need to pull the pan and look around. BTW engine sounded fine while running.
Thanks
Jeff
