Thread: Oil leak
Old 08-08-2006, 07:01 PM
any4xx any4xx is offline
Either could be the culprit. If it IS the valve cover, merely tightening it won't usually stop a leak. It's a pull, re-gasket, re-install. Also, check the mating surface between the intake and the head at the valve cover rail. If the intake wasn't set properly there'll be a lip there and you'll have a heck of a time getting the valve cover to seal.
