Trularin, how about some additional details, maybe a photo of your setup? Which pulley is a March? part number? How about specs on the Ford pulleys, maybe part numbers? Which water pump are you running, long or short? Inquiring minds want to know.
I finally used a stock 1987 Mustang crank and alternator pulley set on my 351W with a standard rotation long water pump. I found a water pump pulley from a 1987 T-bird Turbo Coupe that would work but had to space the crank and alternator forward 1/4" to align everything. Just wondering how you did it and how many hoops you had to jump through to make it all work.
Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
