Old 08-12-2006, 10:18 PM
Mando's Avatar
Mando Mando is offline
I used Lizard Skin in my car . There are a few pictures of the interior before and after the finish was applied. 1 bucket covered the entire footboxes including the roof and sides, the tunnel, the floor and the area behind the seats.
You need to use the spraygun they recommend due to the consistency of the produce. Not even sprayguns used for bodyshultze would spray this stuff. It even comes with a certain type of paddle that attaches to a drill to mix the stuff that so you dont over aerate the mix. You spray on thin layers until its about the same thickness as a credit card. You can sand it smooth and paint it if you need to.
If anyone wants to use this stuff I can send them the gun and all the other bits that comes in the kit including the paddle to do the job. The kits not cheap so it would be worth your while to use mine.
Regards.
Mando
