Old 08-21-2006, 07:46 PM
Michael C Henry Michael C Henry is offline
Cobra Make, Engine: Everett Morrision FE 427 so 2-4s
Default 2x4s tunnel wedge and PCV
I have a Dove tunnel wedge 2x4 intake. Currently their is a 90° PCV valve in each valve cover. They each are vented to a S&H air cleaner base just inside the element. The left valve cover is going to the front carb which is the primary carbruetor. The venting is making the element a mess and coating the carb including the air bleeds. The engine has the breather stack in the center rear and the right front oil filler tube with push on breather in the intake manifold. The left valve covers PCV valve is towards the front and is close to the hood edge not much more room left.
I'm looking for ideas and examlpes on redoing the PCV system . I've thought about running both PCV valves to a Y then a single PCV valve actually controlling the flow into the under side of the intake plenum. Thoughts?
Mike H
