Old 08-22-2006, 04:15 AM
Loadco's Avatar
Loadco Loadco is offline
Cobra Make, Engine: ERA 427 SC
I'm just using one PCV valve. It is attached to the forward carb at the vacuum fitting in the base plate of the carb. I have a oil fill/breather cap in the other valve cover. This setup works fine with one exception. The left bank of cylinders run slightly leaner than the other side due to the PCV drawing it's air below the throttle plate. You can see pictures in my gallery.
ERA #509
2003 Z06
