Old 08-23-2006, 06:23 AM
speed220mph's Avatar
speed220mph speed220mph is offline
Cobra Make, Engine: ERA 427SC w/427so, ERA GT #2002
Mine blew oil out the breathers until I installed a single PCV valve as shown. Heads are tunnel ports with 2X4's up top on tunnel-ram manifold. Used stock oil-filler cap that's well baffled to prevent oil being sucked into intake and an inline PCV valve. Drilled and tapped manifold on opposite side to accept a bushing and AN fitting with 270 degree swivel with pushlock. Setup works well.
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
