Old 08-23-2006, 10:57 AM
HighPlainsDrifter's Avatar
HighPlainsDrifter HighPlainsDrifter is offline
Cobra Make, Engine: F5 Roadster
Default check
Ron,
Take a digital ohm meter and check the 2 wires coming out of the dist.
Disconnect first.
Now rotate the rotor back and forth, the trigger should go from wide open to about 700 ohms when you move the rotor. If it does this your dist is fine.
Good Luck,
Perry.
