Thread: Motor choice
Old 08-26-2006, 01:18 AM
fastraxsg's Avatar
fastraxsg fastraxsg is offline
Evryday is a roadstr day
Cobra Make, Engine: RHD Hurricane street roadster HM1081 aging nicely in the garage
Paul, no matter what happens I seem screwed here, was told after I double checked, no second hand cars can be imported into Indonesia...I also crawled around this "beauty" of mine, and the biggest problem is the frame in the front, its really high and dropping the fenders would require a frame cut too. The other consideration to dropping the nose down is that the motor sits so far forward, those two extra cylinders, it would stick out through the hood, could move the scoop further forward but would make it look oven odder. The rear might be able to be dropped more,will check after I get the lowered springs here. Seems if I rebuild the mount for the shock the tires can go farther up in the wheel well , not sure why it was made like this but might be some wiggle room there. I should see if there was ever a lowered wheel spindle made for the Torana....thanks for thinking of me....I'd probably go crazy being back in the States, too many choices.
aka Fuzzy ............... "It is not the return ON my investment that I am concerned about; it is the return OF my investment".......from Will Rogers
