Old 08-26-2006, 08:40 PM
mickmate's Avatar
mickmate mickmate is offline
It should have 2 tags. One is BPL (British Power Lock) that is limited slip. The other is the ratio. See if you can read that and it will be either a gear ratio directly or the number of teeth on each gear which gives the same thing. I have an article on rebuilding them I can e-mail you and an Alldata printout on them if you'd like it.
mickmate
http://www.actoncustom.com/
