Old 08-29-2006, 08:33 AM
John Annie's Avatar
John Annie John Annie is offline
Cobra Make, Engine: ERA #661 with a 428CJ, Richmond 5 speed
Mike,
You really have problems elsewhere because you shouldn't have to do this, however I've a Speed Demon Carburetor and this was taken verbatim from their Instruction manual regarding priming the carb.
"The best method for priming an empty carburetor
requires a fuel compatible plastic squeeze bottle,
such as BG Part # 130041. Fill the bowl through
the vent tube until fuel is visible in the sight
window. Depress the accelerator pump levers
once or twice until fuel can be discharged from the
pump discharge nozzles....."
John
