Old 08-29-2006, 01:52 PM
Dennis Kelley Dennis Kelley is offline
Cobra Make, Engine: BDR 302 AFR 165
GAsoline evaporates in high temps. Two to three weeks doesn't seem like that long of a time, but how hot is it in your garage. Even if your floats are low there should still be a shot in the accelerator pump. I had a truck that did the same thing and it was a bad diaphram in the fuel pump. I believe you has a bad pump thereby causing fuel to flow back instead of forward.
Later
dennis
