Old 09-03-2006, 02:31 PM
FUNFER2's Avatar
FUNFER2 FUNFER2 is offline
I had Comp Cams grind me my cam. Talked for axp. a hour. The results is a perfect cam, for my driving style. Radical lope, comes in at around 3,000 rpm. (did not want it down too low for the weight of the car) Sounds awesome. 252/260 duration-600 lift- 112 lobe seperation. Solid flat tappet. Earson roller rockers & shafts, double springs, with end stands (a must) Adjust valves once in the spring, checked in summer, backed off in hibernation months. Compression- 10:3:1. Heads- factory steel, ported & polished to the max. I polished most of the alum. on the engine. (still not done) The rest is ceramic coated. Take a look at my gallery for a engine shot. You can email for the full cam specs. and # if interested.
Thanks,
Regards,
Kevin
