Thread: Power Steering?
Old 09-04-2006, 05:07 AM
Default P/S rack and system
Chuck The 428 car is mine. ERA put the system in 2000. Sweet or appleton rack. Works great. Made a bracket (curde) The pump is on the R/S of the motor bottom and uses the 2 lower timing cover bolt holes. My timing cover is one they usefor a front motor mount setup with the 2 lower holes on each side flush with the front of the timing seal. Have a P/S cooler under the rad support and a 1 quart tank from Howe racing ent. The bump steering is gone. running the lines was the only pain. Mounting the tank is on the fire wall. The alignment really makes the car handle alot better with 1.0+ camber,4.0+ caster, 1/16 toe. Ran 3 seconds faster in the local autoX than the before rack was done. New problem is learning not TOO MAN HANDLE CAR!!!! Smooth is faster Rick Lake
