Old 09-04-2006, 10:17 AM
trularin's Avatar
trularin trularin is offline
Member of the north
Cobra Make, Engine: A Cobra
Is it the Lokar, through the firewall braided bracket and cable setup or something just like it?
They generally have the bracket included and may mess with your mind as it does NOT bolt where the 302 has it's backet.
The Lokar and many aftermarket cables setups bolt the bracket to the back of the carb over ( or under ) the two rear bolts. Or just the bolt on the left rear, depending. Then you run the two springs to the throttle and the bracket.
Hope this helps.
