Old 09-05-2006, 12:04 AM
Carnut427 Carnut427 is offline
Cobra Make, Engine: ERA 427 w/496 Side Oiler, roller, dual quads
I change the oil and use Stabil, then spray fogging oil (do a Google on "fogging oil") into the carb while she's running, pull the plugs and spray the fogging oil in each cylinder and replace the plugs. Then loosen the rocker arm bolts to relieve spring tension.
Do you know why they call it "PMS"? Because "Mad Cow Disease" was taken. --Unknown, presumed deceased
