Old 09-07-2006, 01:51 PM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
I am not sure of your question but I will try and answer what I think you need to know. To shorten your pilot shaft, place a straight edge over your bell housing after you have bolt up your transmission. Determine the amount of your pilot shaft that extends beyond the end of your bellhousing (if any). Then determine the difference between your bell housing mounting surface on your block and the end of your crank shaft (you don't need your clutch installed for this). Next with your pilot bushing installed in the back of your crank determine how much of your pilot shaft needs to ride in the bushing (about 3/4" I think). Next take your trans to a trans shop and have the end of your pilot shaft cut off so that you are not riding the end of the pilot shaft against the end of your crank, probably about 3/8" to 1/2" needs to be cut off and beveled.
My appologies if this is not what you are wanting. Maybe someone else can give you a better answer.
Clois
"Let's roll"
"Be part of Something Good
