Old 09-07-2006, 02:27 PM
cleandan cleandan is offline
Originally Posted by MrMagoo
I drive my cobra on the street, mostly. I am running maybe 300 HP max, and I normally dont get the revs past 4500 RPM. I drive it quite a bit, about 3,000 miles a year. I have a Holley Blue electric pump, it's kind of noisy and I have had some fuel pressure fluctuation (I have a holley regulator before the pressure gauge). I was shopping around for a new motor and I noticed most of the pics of 351's I see have mechanical fuel pumps.
I also noticed that my oil temp sensor was connected to the plate where the fuel pump would normally be and I was wondering if this was normal.
Thanks!
With your low rpm driving and smallish HP you will be just fine with a quality mechanical pump. The electric aftermarket pumps do have a use, but mostly they are installed for bragging rights and lack of proper fuel system set up with mechanical pumps. Remember, 427 Thunderbolts ran fairly well with a mechanical pump, as well as many, many other race vehicles.
The oil temp sensor tapped into the fuel pump block off plate seems like a cheap set up. The oil there is splash only and not a very good place to indicate the temp of the bulk of the oil in the system. Adding a bung to the side of your oil pan would be best.
You can't make anything everything proof, so have fun and be careful.
