Thread: Wiring Problemo
Old 09-07-2006, 02:35 PM
jarendall jarendall is offline
Cobra Make, Engine: StreetBeast 66 replica 302 350HP
correct, if you wire the elements individual, you can get by without relays, the VW switch is one wire in and two wires out, I used the single bulb rear lights and had to use relays, as I mentioned before the four bulb setup is much easier to use, glad you found your leak, looks like you are on your way
PapaJohn
