Old 09-09-2006, 01:14 PM
Gatorac's Avatar
Gatorac Gatorac is offline
Cobra Make, Engine: BDR 930, 427 Windsor T56
You must keep the fluid in the clutch system fresh. The slave and master will not last long if you don't. It won't matter if the slave is from a Yugo or a Ferrari.
I have found I need to replace the fluid twice a year. Suck the old fluid out of the master and refill it with new fluid. When bleeding, you can get 3 pumps of the pedal before you need to fill the master back up. Don't try 4. I have to bleed almost a full 12 oz bottle of fluid through it before it starts to look clear.
I also have some insulated sleeving over the hard line from the master to the slave.
Jim Pomroy
Have Fun!
BDR #930
08 Corvette Coupe
92 Sunburst Yellow Miata
#81 Saturn V Miata Crapcan racer
Panoz GTRA #42
