Old 09-11-2006, 05:41 AM
Lowell W Lowell W is offline
Club Cobra Member
Cobra Make, Engine: SPF #1507 427 Dart Block Windsor
Oh, BTW, Chris,
If you haven't already, pull the drain plug on the side of the block and drain all the water. Then turn the motor over a couple of times to push all the water out of that cylinder, squirt in some oil (wouldn't hurt to squirt some oil in all the cylinders while you're at it) and turn it over a couple of more times. It would really suck to have the rings rust in the cylinder after everything else.
Lowell
