Old 09-11-2006, 06:30 PM
Letzbang's Avatar
Letzbang Letzbang is offline
Cobra Make, Engine: Lone Star Comp.
When I went to Denton Dragway last year with my Cobra all they checked was that I had seatbelts and a helmet. They also will not allow you to wear shorts or sandals. Which makes sense anyway. If you get to Denton early on a test and tune night you can make alot of passes before it gets busy. That way you can get used to the track and what you need to do when you get up to the lights. I also liked that you get your timing slip after each run as well. So you can see if your improving or not. For 15 or 20 dollars its a great way to spend a night at the track.
Jeff
