Thread: AN Fitting Leak
Old 09-13-2006, 09:36 AM
CWizard CWizard is offline
Cobra Make, Engine: SPF, 418 Stroker
Default AN Fitting Leak
I hooked up my oil cooler a couple of weeks ago, and there is a persistent small leak at one of the connections to the cooler. It's the standard SPF setup with AN-10 90 degree fittings at the cooler connection. I've tightened to about 12 ft-lbs, which I found recommended as the max torque for -10 fittings. Still leaked, so I added a soft aluminum cone (similar to Earls Conoseal; got it at a local aircraft shop) on top of the tapered nipple on the cooler. Still leaks. I can't see any imperfections on either the 90 deg fitting or the cooler nipple. I know the threads are not supposed to form the seal, but I'm considering adding some teflon tape or something similar. Suggestions, anyone?
Thanks a bunch.
Jerry
