Old 09-18-2006, 04:48 AM
Cobra.au's Avatar
Cobra.au Cobra.au is offline
Cobra Make, Engine: Classic Revival, Gen3 ls1, Vortech T-Trim, Motec, tremec M12, wilwood brakes.
Gav
Things are always easier the second time around, well thats the theory anyhow
The two main reasons I decided to make another set of side pipes are
1. I really hate slip joints as they nearly always leak
2. No one seems to have designed a side pipe with hi flow internal cats (its surprising how poor standard cats flow)that are the right distance along the exhaust so they actual work.
The only other hi flow side pipes I have seen had the cats mounted in the inner guards before the pipes exited out of the side of the car the big draw back of this is the reduce primary length which will rob you of low down torque.
Craig W
Central Coast NSW
