Old 09-18-2006, 08:52 AM
JCoop's Avatar
JCoop JCoop is offline
Cobra Make, Engine: Superformance, FRP460 Big Block
Originally Posted by PJS50
Ray,
When you had your headers/sidepipes apart, did you look at the header flange to see if any of your individual cylinder pipe ends had cracked at the flange junction? I found a couple of cracks there that I had welded up when I did a rebuild... That can also be a source for air in your exhaust
I assume your sidepipes were fine at this same location if you filled in that recess with that Wurth material...?
Pat
Good thought, Pat.
As I recall, however, they were in pretty good shape, except for that concave center section. But you're right, I may have to look closer where they meet in the center.
Thanks
Ray
New York
SPF#1052 11mpg
CAV GT40 MONO29 9mpg
'01 MB CL600 V12 18mpg
'08 Volvo S80 18mpg
